Hyperbit
Oct 31, 2012Aspirant
LIBC6 update
i try to install PyCrypto but i get some errors Preparing to replace python-crypto 2.6-2 (using python-crypto_2.6-2_sparc.deb) ... Unpacking replacement python-crypto ... dpkg: dependency problems...
Etz
Nov 01, 2012Aspirant
Does it start manually?
Shold throw out something like this on success:
Also make sure, it is executable and has correct permissions.
EDIT:
Are you 100% sure its not running, or you just dont have access to WebInterface?
What is the output of:
/etc/init.d/pyload start
11:57:46-root@NAS:~$ /etc/init.d/pyload start
Starting pyLoad server:Daemon PID 3985
EDIT:
ps aux | grep pyLoadCore
