Hyperbit
Oct 31, 2012Aspirant
LIBC6 update
i try to install PyCrypto but i get some errors Preparing to replace python-crypto 2.6-2 (using python-crypto_2.6-2_sparc.deb) ... Unpacking replacement python-crypto ... dpkg: dependency problems...
Etz
Nov 01, 2012Aspirant
Yes, thats what I wanted to suggest doing next, but since I had work to do and also board is constantly "temporarily unavailable", I didnt manage to do it.
Glad that you got it working.
It sometimes a bit hard to give advice for Sparc units, if you dont own one anymore, as they run ancient Debian so sometimes things work a bit differently.
Also Debian on Sparc units is a bit more customized and in some places "castrated" than on x86 units...
Youre probably out of luck with it, unless WhoCares (ReadyNasXtras) decides to bundle it with python addon, ofcourse you could always make suggestion/request to him ;)
Hyperbit wrote: now i only stuck in problem with the pycrypto extension :)
