CasperG
Oct 01, 2017Aspirant
Logitech Media Server fails after RN102 firmware upgrade to 6.8.1
After upgrading my ReadyNAS 102 firmware from 6.8.0 to 6.8.1 my Logitech Media Server NT disappeared from the installed apps. And after reinstalling the Logitech Media Server NT app it it will not la...
- Oct 04, 2017
You have two separate installation of Logitech Media Server -- one appears to be an app from NASTools, and the other is the unmodified package from Logitech. The Logitech (non-app) version is starting, which conflicts with the NASTools app and won't allow it to start.
You'll need to get rid of the old package to allow the app to work. From an SSH command prompt, you can run `apt-get purge logitechmediaserver` to do that.
mdgm-ntgr
Oct 04, 2017NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
Skywalker
Oct 04, 2017NETGEAR Expert
