Petros265
Dec 11, 2016Aspirant
Logitech Media Server for Readynas 212 ARM Firmware 6.60 - clear installation instructions?
I have just switched from an old Readynas Duo to the Readynas 212, and am appreciating the step change in performance. However I want to stream my FLAC audio library to my Logitech Squeezboxes ov...
- Dec 13, 2016
I finally removed the version of LMS 7.9 from Nastools and installed this one instead from GitHub
Initially it gave the same error message but after a few minutes it spontaneously started and I have now restored full Logitech Media Server functionality to my ReadyNAS plus Logitech Squeezboxes.
Thanks for the help.
Best regards
Peter
FramerV
Dec 12, 2016NETGEAR Employee Retired
Hi Petros265,
I do not have the step by step guide on it. But you could probably start with the following links:
Guide on how to download and install apps locally.
Then get the actual app from the link below:
Community app compatibility with ReadyNAS OS 6.6.0
- Petros265Dec 13, 2016Aspirant
Thanks for the very helpful reply. Have uploaded the LMS NT 7.9 package which installs automatically. However when I try to start it, it immediately crashes. Once it got as far as giving an error message about 'Empty ...'.
I have tried rebooting, deleting and reinstalling but it sill sits there refusing to Turn on or launch.
Any ideas gratefully received.
Peter
Message is Empty Resource Error. Bad NML call.
Best regards
Peter
