anonynas
Mar 06, 2011Aspirant
Mercurial (hg) SCM on ReadyNAS?
Hi All, I was wondering if anyone has successfully installed Mercurial on their ReadyNAS. I'm struggling because I can't seem to get a complete Python install. I downloaded and installed Python ...
ddumont
Apr 07, 2011Aspirant
Trying to configure RhodeCode.
Got it installed and set up but I need the help of a readynas guru.
I'm stuck here:
http://packages.python.org/RhodeCode/se ... st-example
I think I've found the frontview http conf file, which imports conf files stored in an addons folder. So I know I can add one for rhodecode there.
I'm not sure what to put in it though, does frontview have the proxy support?
Can you recommend how my config file should look?
Also, I've installed rhodecode in a python virtual environment. Do you have any suggestions on how I can auto launch this web service on startup?
If anyone has interests in getting mercurial and rhodecode set up as plugins for the readynas, I'd be more than happy to share how I've managed to get this far.
I'm stuck here:
