anonynas
Mar 06, 2011Aspirant
Mercurial (hg) SCM on ReadyNAS?
Hi All, I was wondering if anyone has successfully installed Mercurial on their ReadyNAS. I'm struggling because I can't seem to get a complete Python install. I downloaded and installed Python ...
WhoCares_
Apr 07, 2011Mentor
Adding virtual hosts to the Apache config isn't trivial because it's not enabled in the default config on the ReadyNAS (which I believe is a real bug). So you may try with the subdirectory example for that's easier to implement.
-Stefan
-Stefan
