rblanco
Oct 17, 2017Aspirant
Milestone Arcus license entry
I am trying to enter the license with no success. When I login to https://milestone.netgear.com/, with MyNETGEAR credentials, the following error appears: "Could not open Hibernate Session f...
- Oct 23, 2017
Hi Marty_M,
The issue has been resolved by the Netgear support team. There was a problem with the portal.
Thank you.
Marty_M
Oct 23, 2017NETGEAR Employee Retired
Hello rblanco,
It does appear that you are having trouble activating the license for Milestone Arcus. I may need to seek assistance with the concern to the appropriate department since when I try it just does not load and stuck. May I ask for a screenshot of the error message you are getting for reference.
Welcome to the community!
Marty_M
NETGEAR Community Team
- rblancoOct 23, 2017Aspirant
Hi Marty_M,
Thank you.
