  • Hello!
    An app that finds:
    1: Exact clones
    2: Duplicates, the same content but different file name
    And can erase the ones I choose.
    Pc example: Heatsoft Clone Cleaner 2:01
    Br
  • Is utorrent for R6 available anywhere? I can install myself, but I'd like to have it in the console to start/stop. Unless that's trivial to add now...
  • The debian 7 64 bit version of utorrent here worked fine. http://www.utorrent.com/downloads/linux. I set it up manually and it works fine.
    Would be cool if someone could write a script that would create a web start/stop icon on the installed apps page for any specified script in init.d. Like:
    $ displayService -add icon=foo.ico summary="summary text" moreinfo="URL" servicename-in-etc-init.d
    Then when I add something to the nas I can easily add it to the web ui.
    steve
  • I'd like a nice version of MYSQLBackup, as previously done by WhoCares for the ver 4 series of ReadyNAS operating systems.
    I can work around with shell script + cron, but a proper integration into FrontView on OS6 makes it all so much cleaner and simpler.
ProSupport for Business
