BaJohn's avatar
BaJohn
Virtuoso
Feb 20, 2016
My LAMP hits 'glass ceiling'.
I've been looking into the workings of and updating of the LAMP packages. Using the standard updating facilities (apt-get, aptitude, dselect) this is the current version status on my ReadyNAS.   ...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Feb 21, 2016
    Attempting to update apache to a newer version would likely break it, I would think. Updating PHP may break some of the available apps. Not sure on the other packages.
    In the future we might do some updates that may be relevant to what you are after, but I don't have a timeline on that. Certainly not in the imminent future.
ProSupport for Business
