TanTran
Jul 19, 2019Aspirant
NAS Ready NV+ mainboard fried
Hi all, My ReadyNAS NV+ mainboard is fried. It has 4 x 1TB disks in RAID5 and I don't have external backup. Can I purchase a replacement model and insert 4 x disks into the replacement and able to ...
Jul 19, 2019Guru - Experienced User
The info below is old, but should still work.
Mounting Sparc-based ReadyNAS Drives in x86-based Linux By dbott | October 17, 2009 Update – Thanks to Peter Schlesinger in the comments section below: Simple step by step guide to mounting Sparc-based ReadyNAS Drives in x86-based Linux: Tested on brand new install of Ubuntu 10.10 (32bit x86), no other dependencies- 23rd Jan 2011 In a terminal window: (1) sudo su (2) apt-get install fuseext2 (3) apt-get install lvm2 (4) modprobe fuse (5) vgscan (6) vgchange -ay c (7) fuseext2 -o ro -o sync_read /dev/c/c /mnt That’s it!!! You can now see the mounted files in the /mnt directory (NB: Without the “-o sync_read” option to fuseext2 I had problems with copying large files.
It kept saying the source file wasn’t found. After adding this option everything worked fine).
