sylvainp's avatar
sylvainp
Need help for shared permission and dual redundancy
Hi all, I have been using my ReadyNAS Pro (6 bays) for many years and upgrade (CPU, Memory, and OS) Now using OS 6.xx
Recently I lost all my volume (all red) probably a corrupt system files or Netdata screw something because after a reboot this happen.
I have all my files backup to an external USB drive connect to the NAS. So I factory reset and start from scratch. At the moment I use 3 x 3TB drives (X-Raid 5 mode) and I have 2 spares drives. I wanted to use dual redundancy with 4 drives but I never got the option
when I factory default. Can I change to dual redundancy from a X-RAID 5 mode without restart everything ?
Another issue with Shared folder permission. I have 1 PC which I use as Admin rights and have a NUC, media player, Roon to access music on the NAS. For many years I use Genie Timeline Pro to backup my files and documents. The backup times are slow and I found the restore not reliable and I lost some files because the software couldn't restore it. So I look for a backup software alternative and I end up with AOMEI Backupper Pro on sale.
When I create my shared folder on the NAS I select SMB (not legacy mode or SMB 1.0) and all users for permission but by default (anonymous to access shared folder) is enable. So I deactivate (anonymous access). For a reason AOMEI Backupper cannot write to my Shared folder "Backup" but what is strange I can access and write to the shared folder "backup" with the PC.
The only way I can make backup with AOMEI Backupper is if I set the permission to "anonymous can access shared folder"
All Users as permission don't work. If I remember I didn't have this issue with Genie Timeline Pro.
What could cause the backup software to not have access and write on my shared folder if the anonymous access is not enable ?
Is there a security issue by using the anonymous user to access my shared folders ?
Thank you
  • StephenB's avatar
    It sounds like the backup software is giving the NAS a username that doesn't exist on the NAS.
    If you switch to flexraid you should be able to add a disk for redundancy.
    • sylvainp's avatar
      sylvainp
      When I try to execute the backup I have a prompt to enter username and password.
      So I enter "Admin" and my password : The same I use to access the NAS Admin Page.
      This software only work in anonymous access which I don't want to use.
      • sylvainp's avatar
        sylvainp
        Looks like I need to use SMB Legacy Windows Discovery to make it work. I think this is SMB 1.0 compatibility mode.
        I read some concern about using SMB 1.0  is vulnerable for privacy and security issue.
        Very strange this software need the SMB Legacy Windows Discovery to work.
ProSupport for Business
