xren
May 24, 2017Follower
Need help with Surveillance on readyNAS 204
Hi I need help to get surveillance app work on my readyNAS 204, The app is installed from readynas app store without any issue but however when I click the launch button or access it on port 510...
viperhansa
Jun 05, 2017Virtuoso
Depending on your system, just install the correct PHP add-on from app-store..
You can find it here: Netgear NAS apps
// Hans
Jun 05, 2017Guru - Experienced User
Surveillance should be a self contained app though.
- Nov 24, 2016Retired_Member
