xren
May 24, 2017Follower
Need help with Surveillance on readyNAS 204
Hi I need help to get surveillance app work on my readyNAS 204, The app is installed from readynas app store without any issue but however when I click the launch button or access it on port 510...
viperhansa
Jun 05, 2017Virtuoso
Depending on your system, just install the correct PHP add-on from app-store..
You can find it here: Netgear NAS apps
// Hans
Rdhrdh
Jun 05, 2017Aspirant
Sorry I'm not sure i'm im following correctly here. Installing one of the NAS PHP apps will allow the surveillance app to run properly in my browser?
- StephenBJun 05, 2017Guru - Experienced User
You're not the only one.
Surveillance is a self-contained app provided by Netgear. There shouldn't be any need to install a third-party app to get it to work.
- mdgm-ntgrJun 05, 2017NETGEAR Employee Retired
Do you see anything for PHP in packages.log ?
- RdhrdhJun 05, 2017Aspirant
Not sure if this was addressed to me or not but i'll take a look when I get home from work. I was able to get the login screen to somewhat populate on IE but it was unreadable and couldn't log in.
- Nov 24, 2016Retired_Member
