cpu8088
Jul 15, 2016Virtuoso
netdata NT not working
installed this app on my 2120 v2 and pro 6 running with xeon quad 3230 with firmware 6.5.1 both got error message showing "" Service Temporarily Unavailable The server is temporarily unable...
- Jul 18, 2016
cpu8088 wrote:""
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache/2.2.31 (Debian) Server at 192.168.1.xx Port 443""
amazz20 wrote:
Looking at the syslog while turning the app on I get:
400699 Date Today 22:45:12 Host Ezekiel Messagetype Syslog Syslogtag apache2 ProcessID 22660 Message [error] (111)Connection refused: proxy: HTTP: attempt to connect to 127.0.0.1
:19999 (localhost) failedThe Apache web server is responsible for proxying requests to netdata so that you can go to https://NAS/apps/nastools-netdata instead of http://NAS:19999, and use the ReadyNAS user list for authentication. Those errors mean that Apache can't connect to netdata.
Running systemctl status fvapp-nastools-netdata via SSH should give a good clue as to what's going on. Do either of you have IPv6 disabled by any chance?
JennC
Jul 16, 2016NETGEAR Employee Retired
Hello cpu8088,
Did you install from the Available apps or just manually?
I tried installing this from the available apps and it was successful and monitors the performance.
Can you try both?
cpu8088
Jul 16, 2016Virtuoso
tried manual install on both nases
still the same
used firefox 47.0.1 and internet explorer 9
- amazz20Jul 17, 2016Guide
I am having the same issue on my RN202 running 6.5.1, also have tried installing it both ways.
While watching the CPU utilization using iStat, while it is on, it is using 3 percent. So, it is doing something just not able to display it.
:19999 (localhost) failedAlso these two:
uID 420552 Date Today 23:01:04 Host Ezekiel Messagetype Syslog Syslogtag LogAnalyzer ProcessID 2265 Message [error] [client 127.0.0.1
] File does not exist: /var/www/stubuID 420552 Date Today 23:01:04 Host Ezekiel Messagetype Syslog Syslogtag LogAnalyzer ProcessID 2265 Message [error] [client 127.0.0.1
] File does not exist: /var/www/stub_status
