cpu8088
Jul 15, 2016Virtuoso
netdata NT not working
installed this app on my 2120 v2 and pro 6 running with xeon quad 3230 with firmware 6.5.1 both got error message showing "" Service Temporarily Unavailable The server is temporarily unable...
- Jul 18, 2016
cpu8088 wrote:""
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache/2.2.31 (Debian) Server at 192.168.1.xx Port 443""
amazz20 wrote:
Looking at the syslog while turning the app on I get:
400699 Date Today 22:45:12 Host Ezekiel Messagetype Syslog Syslogtag apache2 ProcessID 22660 Message [error] (111)Connection refused: proxy: HTTP: attempt to connect to 127.0.0.1
:19999 (localhost) failedThe Apache web server is responsible for proxying requests to netdata so that you can go to https://NAS/apps/nastools-netdata instead of http://NAS:19999, and use the ReadyNAS user list for authentication. Those errors mean that Apache can't connect to netdata.
Running systemctl status fvapp-nastools-netdata via SSH should give a good clue as to what's going on. Do either of you have IPv6 disabled by any chance?
NAStools
Jul 18, 2016Luminary
cpu8088 wrote:""
amazz20 wrote:Looking at the syslog while turning the app on I get:
400699 Date Today 22:45:12 Host Ezekiel Messagetype Syslog Syslogtag apache2 ProcessID 22660 Message [error] (111)Connection refused: proxy: HTTP: attempt to connect to 127.0.0.1 :19999 (localhost) failed
- cpu8088Jul 18, 2016Virtuoso
ipv6 was disabled
now enabled under network and netdata NT is working
thanks
- NAStoolsJul 18, 2016Luminary
cpu8088 wrote:ipv6 was disabled
I thought that might be it. I have the default configuration of netdata set to listen on IPv6 loopback, which should listen on IPv4 loopback as well. Shouldn't need to have IPv6 enabled. I'll look into it.
- cpu8088Jul 19, 2016Virtuoso
whilst this netdata NT is working on both 2120 v2 arm cpu and pro6 with xeon quad, i noticed that under system overview the disk read should be disk write and disk write should be disk read?
if the system overview showing disk temp cpu temp, motherboard temp, fan speed would be ideal
