tommyhackett
Jun 19, 2022Aspirant
New drive not being used in RAID, management service offline
Im using a ReadyNAS202 running 2 x 2TB WD red drives I noticed my Time Machine backups were starting to fail and then realised one of my disks was degraded. I replaced that with a new one earlier ...
Jun 20, 2022Guru - Experienced User
Are you running XRAID or FlexRAID?
- tommyhackettJun 20, 2022Aspirant
I don't remember making the choice, how is this determined?
- StephenBJun 20, 2022Guru - Experienced User
XRAID is the default, so if you didn't choose FlexRAID you are running XRAID.
Can you post a screenshot of the volumes page in the admin web ui?
- tommyhackettJun 21, 2022Aspirant
Ok sure, yep definitely never chose FlexRAID.
I can't get into the web admin UI, it seems to kind of accept my credentials then time out.RAIDar says "Management service offline" and diagnostics shows "Failed to start ReadyNAS System Daemon"
- Jun 10, 2022Retired_Member
