tommyhackett
Jun 19, 2022Aspirant
New drive not being used in RAID, management service offline
Im using a ReadyNAS202 running 2 x 2TB WD red drives I noticed my Time Machine backups were starting to fail and then realised one of my disks was degraded. I replaced that with a new one earlier ...
tommyhackett
Jun 20, 2022Aspirant
I don't remember making the choice, how is this determined?
Jun 20, 2022Guru - Experienced User
XRAID is the default, so if you didn't choose FlexRAID you are running XRAID.
Can you post a screenshot of the volumes page in the admin web ui?
- tommyhackettJun 21, 2022Aspirant
Ok sure, yep definitely never chose FlexRAID.
I can't get into the web admin UI, it seems to kind of accept my credentials then time out.RAIDar says "Management service offline" and diagnostics shows "Failed to start ReadyNAS System Daemon"
- StephenBJun 21, 2022Guru - Experienced User
Was the new disk formatted when you installed it?
Does entering
cat /proc/mdstattell you that the array for the data volume (md127) is resyncing?
You could try testing sdb (the new disk) with smartctl.
I didn't do anything to format the new disk before inserting it, I didn't think I would need to and I'm not sure how I would go about doing that?
proc/mdstat is giving me this
root@TXHReadyNAS:~# cat /proc/mdstat
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid1 sda3[1]
1948662784 blocks super 1.2 [2/1] [_U]
md1 : active raid1 sda2[0]
523264 blocks super 1.2 [2/1] [U_]
md0 : active raid1 sda1[1]
4190208 blocks super 1.2 [2/1] [_U]
unused devices: <none>======
To use smartctl, would the below command be correct? As I'm not clear on how to specify the device type. The response I get at this point is the same for sda and sdb
root@TXHReadyNAS:~# smartctl --all dev/sdb
smartctl 6.6 2017-11-05 r4594 [armv7l-linux-4.4.218.alpine.1] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.orgdev/sdb: Unable to detect device type
Please specify device type with the -d option.Use smartctl -h to get a usage summary
- Jun 10, 2022Retired_Member
