zennit
Feb 24, 2012Aspirant
perl issues on duo
trying to install gitolite on my readynas duo which uses perl but getting Can't locate English.pm
how would I go about adding this to perl?
Do I have to apt-get some modules?
- zennitAspirantaha
perl-modules: /usr/share/perl/5.8.8/English.pm - WhoCares_MentorOk, so to make apt-get happy, try to do this:
dpkg -r php5-ldap
apt-get install --reinstall perl-modules
-Stefan - zennitAspirantnas-C7-F3-68:/opt/git# dpkg -r php5-ldap
(Reading database ... 15167 files and directories currently installed.)
Removing php5-ldap ...
Processing triggers for libapache2-mod-php5 ...
Your apache2 configuration is broken, so we're not restarting it for you. - zennitAspirantnas-C7-F3-68:~# apt-get --reinstall perl-modules
E: Invalid operation perl-modules
nas-C7-F3-68:~# apt-get install --reinstall perl-modules
Reading Package Lists... Done
Building Dependency Tree... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 78 not upgraded.
Need to get 2310kB of archives.
After unpacking 0B of additional disk space will be used.
Do you want to continue? [Y/n] - WhoCares_MentorYeah, was to be expected. Doesn't matter, the function tried to restart apache with the wrong config.
-Stefan - WhoCares_Mentorthe command is:
-Stefan - zennitAspirantnas-C7-F3-68:~# apt-get install --reinstall perl-modules
Do you want to continue? [Y/n] y
Get:1 http://www.readynas.com readynas/ perl-modules 5.8.8-7.infrant2 [2310kB]
Fetched 2310kB in 9s (253kB/s)
(Reading database ... 15165 files and directories currently installed.)
Preparing to replace perl-modules 5.8.8-7.infrant2 (using .../perl-modules_5.8.8-7.infrant2_all.deb) ...
Unpacking replacement perl-modules ...
dpkg: perl-modules: warning - conffile `etc/Net' is not a plain file or symlink (= `/etc/Net')
Setting up perl-modules (5.8.8-7.infrant2) ...
dpkg: perl-modules: warning - conffile `/etc/Net' is not a plain file or symlink (= `/etc/Net') - zennitAspirantnas-C7-F3-68:/opt/git# gitolite/src/gl-system-install
"make_path" is not exported by the File::Path module
Can't continue after import errors at gitolite/src/gl-system-install line 5
BEGIN failed--compilation aborted at gitolite/src/gl-system-install line 5. - WhoCares_MentorI hate to repeat myself but that was to be expected, too. "Perl too old error". You can try to update the module using CPAN but I don't give any guarantees this won't break your ReadyNAS.
-Stefan - zennitAspirantsounds scary
