mugur
Oct 30, 2015Aspirant
Please help a newbee :(
Hello, i am new here, please bare with me. I might also be stupid... Long story short: ReadyNas RN104. Only app installed is OpenERP. What i need is to get acces to the OpenERP files so i can ...
- Oct 30, 2015
Start by accessing the NAS data volume with SMB/CIFS. The default volume name is "data".
That is, \\nasipaddress\data in file explorer (Windows). You need to be using NAS admin credentials (username=admin, password=NAS admin password).
Alternatively, you can map the volume to a windows drive letter using the command line.
net use * /delete
net use t: \\nasipaddress\data /user=admin password
Then look in the .apps folder (hidden, but you can navigate into it). That is where the apps are supposed to store their data, so your jpgs are likely in there.
Oct 30, 2015Guru - Experienced User
net use * /delete
mugur
Thank you Stephen,
that worked great. Can i bother you with one more question, please?
In the "free apps" i have with my RN104, i have OpenERP there. But as i found out, i can install manually another debian package,
otherwise said, a new version of OpenERP. So i have downloaded odoo_8.0.deb and installed it on my NAS.
After a while, i've got the message OpenERP8.0 installed succesfully. All things are great till now.
But once i am done with this, where i can find the new "manually" installed app?
Cannot seem to be able to find it / launch it anywhere.
Can you please help with this too?
Thank you!
