mugur's avatar
mugur
Please help a newbee :(
Hello, i am new here, please bare with me. I might also be stupid...   Long story short: ReadyNas RN104. Only app installed is OpenERP. What i need is to get acces to the OpenERP files so i can ...
  • StephenB's avatar
    Oct 30, 2015
    Start by accessing the NAS data volume with SMB/CIFS.  The default volume name is "data".
    That is, \\nasipaddress\data in file explorer (Windows).  You need to be using NAS admin credentials (username=admin, password=NAS admin password).
    Alternatively, you can map the volume to a windows drive letter using the command line.
    net use * /delete
    net use t: \\nasipaddress\data /user=admin password
    Then look in the .apps folder (hidden, but you can navigate into it).  That is where the apps are supposed to store their data, so your jpgs are likely in there.
ProSupport for Business
