Pinkyg
Apr 03, 2017Apprentice
Plex not working after OS Reinstall
Hi All, Over the weekend I had to do an OS Reinstall to gain access back to the rn214 admin page (due to the readycloud account deletions). Since then PMS will not run. If I click on Plex in ...
mdgm-ntgr
Apr 03, 2017NETGEAR Employee Retired
Update to 6.7.0 and try installing the app over the top of itself.
- PinkygApr 03, 2017Apprentice
Thanks mdgm,
I wasn't aware there was a newer firmware, don't recall it popping up on the admin page.
I'll do that at the next opportunity and report back.
Thanks again
Geoff
Hi mdgm,
I've went to the NAS admin page and checked for updates. Message says I'm on the latest firmware.
For clarity I'm on 6.6.1
Thanks
Geoff
OK....I've downloaded and uploaded the new firmware, rebooting now.
Firmware can be downloaded from here :
https://kb.netgear.com/000038354/ReadyNAS-OS-6-Software-Version-6-7-0?cid=wmt_netgear_organic
Plex ran straight away after 6.7.0, didn't need to reinstall.
- Blueray3Apr 03, 2017Guide
In case this helps others: Could not access admin page via ReadyCloud or Raidar 4.3.8 on same network. Could not access RN 312 and 212. ReadyNAS Pro 2 had no problems. On the 312 and 212 I could access shares from the inhouse network, but not the admin page. Did a firmware reset and data was saved but Plex denied connection. Tried to remove Plex, removal unsuccessful. Clicking on admin page for finding new firmware said I had the latest (6.6.1?).
Read here there was a 6.7. Downloaded and installed it and Plex started right up. Seems like strange problems. Anyone know what they were?
Thanks
- mdgm-ntgrApr 04, 2017NETGEAR Employee Retired
There was an issue on recent firmware where when you did a firmware update or OS Re-install the installed packages list could get a little messed up. This was resolved in 6.7.0.
- Jul 15, 2018Retired_Member
