schecter948's avatar
schecter948
OS Reinstall/Factory reset not working
Hello Community ,
I´ve trouble with my RNDX4420 , because i  have no access to the webpage. It appears in Raidar and match the ip address in my network. Also i can ping it with my computer.
Now, here is my problem: i want to reset the entire Readynas, but every time when i try, it fails after an OS reinstall or facotry reset.
I go through the steps in the description:
select  to the boot menü,  select the factory reset , i wait  for passed disk test , format the disk and  configure my raid .   Then on the display appers the selected   configuration. About 10 sec later,  the display shows: Err: Raid creation failed.
With an OS  Reinstall  nothing happened.  When i select the OS Reinstall it switchs to the factory reset and  fails again.
I tried different methods to solve the problem, but nothing worked. I stuck in this "Raid creation failed".
Also i have no access to the webpage from the nas.
RNDX4420
FW:4.2.8
Can you help me please?
  • StephenB's avatar
    Nov 03, 2017
    schecter948 wrote:
    Probably it´s the old firmware that can´t handle larger space than 2tb.
    Yes.
    Note some of the rackmount chassis can't handle > 2 TB disks in every slot (a hardware limitation).  But that's not an issue with the RN4200v2.  So you should upgrade the firmware - that will let you use the larger disks.
  • StephenB's avatar
    Your firmware is very old.  How large is the disk you have inserted?  Was it working in the NAS before you tried the reset?
    • schecter948's avatar
      schecter948
      ok...
      you gave me the idea. i solved the problem now.
      I ´ve tried a WD Red 4tb, Seagate st4000, WD Green 3tb, WD blue 3TB . Same problem for all disks.
      Now, i´ve added a 1tb wd blue and it works. ^^
      Thanks man!!
      • StephenB's avatar
        Yes.
ProSupport for Business
