schecter948
Nov 03, 2017Aspirant
OS Reinstall/Factory reset not working
Hello Community , I´ve trouble with my RNDX4420 , because i have no access to the webpage. It appears in Raidar and match the ip address in my network. Also i can ping it with my computer. Now, ...
- Nov 03, 2017
schecter948 wrote:
Probably it´s the old firmware that can´t handle larger space than 2tb.
Yes.
Note some of the rackmount chassis can't handle > 2 TB disks in every slot (a hardware limitation). But that's not an issue with the RN4200v2. So you should upgrade the firmware - that will let you use the larger disks.
Nov 03, 2017Guru - Experienced User
Your firmware is very old. How large is the disk you have inserted? Was it working in the NAS before you tried the reset?
schecter948
ok...
you gave me the idea. i solved the problem now.
I ´ve tried a WD Red 4tb, Seagate st4000, WD Green 3tb, WD blue 3TB . Same problem for all disks.
Now, i´ve added a 1tb wd blue and it works. ^^
Thanks man!!
- StephenBNov 03, 2017Guru - Experienced User
Yes.
- SandsharkNov 03, 2017Sensei
And since you've already done a factory default, now would be the time to consider moving to OS6 on your 4200V2. It's not officially supported by Netgear, but it works and aleviates several problems related to the old Debian distro OS 4.2.x is based on.
- mdgm-ntgrNov 03, 2017NETGEAR Employee RetiredThe RNDX4420 is a desktop 4-bay ReadyNAS, the NVX that shipped with 4x2TB disks.
The NVX can’t run OS6 as it has a 32-bit CPU.
