schecter948's avatar
schecter948
OS Reinstall/Factory reset not working
Hello Community , I´ve trouble with my RNDX4420 , because i  have no access to the webpage. It appears in Raidar and match the ip address in my network. Also i can ping it with my computer.   Now, ...
  • StephenB's avatar
    Nov 03, 2017
    schecter948 wrote:
    Probably it´s the old firmware that can´t handle larger space than 2tb.
    Yes.
    Note some of the rackmount chassis can't handle > 2 TB disks in every slot (a hardware limitation).  But that's not an issue with the RN4200v2.  So you should upgrade the firmware - that will let you use the larger disks.
ProSupport for Business
