Pinkyg
Apr 03, 2017Apprentice
Plex not working after OS Reinstall
Hi All, Over the weekend I had to do an OS Reinstall to gain access back to the rn214 admin page (due to the readycloud account deletions). Since then PMS will not run. If I click on Plex in ...
mdgm-ntgr
Apr 03, 2017NETGEAR Employee Retired
Update to 6.7.0 and try installing the app over the top of itself.
Blueray3
Apr 03, 2017Guide
In case this helps others: Could not access admin page via ReadyCloud or Raidar 4.3.8 on same network. Could not access RN 312 and 212. ReadyNAS Pro 2 had no problems. On the 312 and 212 I could access shares from the inhouse network, but not the admin page. Did a firmware reset and data was saved but Plex denied connection. Tried to remove Plex, removal unsuccessful. Clicking on admin page for finding new firmware said I had the latest (6.6.1?).
Read here there was a 6.7. Downloaded and installed it and Plex started right up. Seems like strange problems. Anyone know what they were?
Thanks
- mdgm-ntgrApr 04, 2017NETGEAR Employee Retired
There was an issue on recent firmware where when you did a firmware update or OS Re-install the installed packages list could get a little messed up. This was resolved in 6.7.0.
- Jul 15, 2018Retired_Member
