readyornot's avatar
readyornot
Port Forwarding: Protocol Type
My router/firewall wants me to specify a protocol type for port forwarding. The choices are things like ICMP(1), IGMP(2), TCP(6), etc. Or I can tell it "Custom IP Type". Anyone know which I should choose?
Also, do I need a static public IP for Photos II to work? I don't think my ISP gives me a static IP.
  • Photos II defaults to 8086. If you want to set it to another port, just go into frontview and select Photos II from the addons. On the Summary tab you can change the port used.
  • Does your router support UPnP? If so, Photos2 will do the port forwarding on its own, with no setup by you. It would be TCP based.
  • No, it does not support UPnP. I was able to get Photos II working using TCP as the protocal. Thanks!
  • I actually have not been able to get Photos II to work outside my network. I still believe the problem is related to properly setting up port forwarding on my SonicWall Firewall. The SonicWall device wants me to specify a "protocol" as well as a port to forward. I went with the above advice to use TCP as a protocol which I thought fixed the problem, but it doesn't. Is there consensus that TCP is the correct protocol? Does anyone know why TCP has a "(6)" following it? Is that the normal port for TCP? I thought HTTP would be the protocol to use, but it isn't an option to use it to create what SonicWall calls a "service object", which is necessary to create the necessary NAT rules.
    Photos II is a neat little add-on that works nicely at home...I just wish I could configure my firewall so i could share my photos with someone other than my wife!
ProSupport for Business
