tomi17250
Jul 11, 2010Aspirant
PPtP Client issues on ReadyNas Duo
Thanks to the HowTo wrote by kraney (http://www.readynas.com/forum/viewtopic.php?f=35&t=33132) I was able to set a PPtP client with the pptp-linux package on my ReadyNas Duo and thanks to the inc HowT...
kraney
Jul 23, 2011Aspirant
There shouldn't be any need to use iptables on the readynas, it works just fine without it. I suspect your problem is on your client side since it works from windows.
The tools you'll want are traceroute on your client side, and tcpdump on the readynas. Using tcpdump you should be able to see if packets from the client are arriving. You need to determine if it's the client packets that aren't making it to the readynas, or the server responses that aren't making it back to the client. Since you'll be remotely logged in to the readynas, you'll want to run tcpdump with a host filter to filter out your ssh traffic, like 'host not <where I logged in from>'.
