vici1's avatar
vici1
Problem with cryptsetup
Hi,
As some of you may know from my other posts, I am trying to find a way to encrypt my data. The data has to be decrypted on-the-fly by the Readynas (Ultra 2). The clients are not encryption aware.
I thought I might try cryptsetup using loopback. That way I could get the Readynas to locally mount the encrypted file (manually, using ssh after reboot). Perhaps I could even write a Frontview addon for entering the passphrase and mounting the disk!
#### this is a 4.2.19 Readynas Ultra 2 after factory default
#### FIRST INSTALL apt-utils
nas-C1-5D-C4:/lib# apt-get -f install apt-utils
Reading package lists... Done
Building dependency tree... Done
The following NEW packages will be installed:
apt-utils
0 upgraded, 1 newly installed, 0 to remove and 30 not upgraded.
Need to get 198kB of archives.
After unpacking 496kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
apt-utils
Install these packages without verification [y/N]? y
Get:1 http://archive.debian.org etch/main apt-utils 0.6.46.4-0.1+etch1 [198kB]
Fetched 198kB in 3s (51.6kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously deselected package apt-utils.
(Reading database ... 14737 files and directories currently installed.)
Unpacking apt-utils (from .../apt-utils_0.6.46.4-0.1+etch1_i386.deb) ...
Setting up apt-utils (0.6.46.4-0.1+etch1) ...
nas-C1-5D-C4:/lib#
#### THEN INSTALL cryptsetup
nas-C1-5D-C4:/lib# apt-get -f install cryptsetup
The following extra packages will be installed:
dmsetup
Suggested packages:
initramfs-tools linux-initramfs-tool
cryptsetup dmsetup
0 upgraded, 2 newly installed, 0 to remove and 30 not upgraded.
Need to get 0B/300kB of archives.
After unpacking 823kB of additional disk space will be used.
Do you want to continue [Y/n]? y
dmsetup cryptsetup
Selecting previously deselected package dmsetup.
(Reading database ... 14753 files and directories currently installed.)
Unpacking dmsetup (from .../dmsetup_2%3a1.02.08-1_i386.deb) ...
Selecting previously deselected package cryptsetup.
Unpacking cryptsetup (from .../cryptsetup_2%3a1.0.4+svn26-1_i386.deb) ...
Setting up dmsetup (1.02.08-1) ...
Setting up cryptsetup (1.0.4+svn26-1) ...
nas-C1-5D-C4:/lib#
#### Note than the reason it did not need to download the packages was that I had installed them, got a warning I needed apt-utils,
#### removed them again and then started as shown at the top.
#### THEN INSTALL cryptmount
nas-C1-5D-C4:/lib# apt-get -f install cryptmount
cryptmount
Need to get 46.5kB of archives.
After unpacking 205kB of additional disk space will be used.
cryptmount
Get:1 http://archive.debian.org etch/main cryptmount 1.2-1 [46.5kB]
Fetched 46.5kB in 3s (11.8kB/s)
Selecting previously deselected package cryptmount.
(Reading database ... 14806 files and directories currently installed.)
Unpacking cryptmount (from .../cryptmount_1.2-1_i386.deb) ...
Setting up cryptmount (1.2-1) ...
Adding system startup for /etc/init.d/cryptmount ...
/etc/rc0.d/S48cryptmount -> ../init.d/cryptmount
/etc/rc6.d/S48cryptmount -> ../init.d/cryptmount
/etc/rcS.d/S28cryptmount -> ../init.d/cryptmount
nas-C1-5D-C4:/lib#
#### CREATE a 50.000.000 byte file and make it available thorugh /dev/loop0
#### (I know, dd is faster, but this was only a test on a small file)
nas-C1-5D-C4:/lib# head -c 50000000 /dev/zero >/c/_testf
nas-C1-5D-C4:/lib# losetup /dev/loop0 /c/_testf
#### encrypt
nas-C1-5D-C4:/c# cryptsetup luksFormat /dev/loop0
WARNING!
This will overwrite data on /dev/loop0 irrevocably.
Are you sure? (Type uppercase yes): YES
Enter LUKS passphrase:
Verify passphrase:
Failed to setup dm-crypt key mapping.
Check kernel for support for the aes-cbc-essiv:sha256 cipher spec and verify that /dev/loop0 contains at least 133 sectors.
Failed to write to key storage.
Command failed.
nas-C1-5D-C4:/c#
As you can see, I have run into problems. It seems the encryption kernel modules are not installed (factory reset 4.2.19).
I have tried installing kernel modules before (while trying to install truecrypt) but have not had success.
Can anyone walk me through the procedure to install the required modules?
Thanks.
1 Reply
  • Hi vici,
    I too am wanting to run TrueCrypt on my ReadyNAS Pro.
    Best of luck and I will watch your progress with interest (unfortunately I am not in a position to give any advice).
ProSupport for Business
