jiska78
Jul 27, 2016Tutor
Problems installing Python #27233558
Can someone please translate this error in to English?
My knowledge of Linux is limited, at best. I am just following Google suggestions.
Thanks
root@NAS01:/var/log/readynasd# a...
jiska78
Aug 11, 2016Tutor
Latest firmware
NO apps installed
mdgm-ntgr
Aug 15, 2016NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
- jiska78Aug 15, 2016Tutor
Done
- mdgm-ntgrAug 15, 2016NETGEAR Employee Retired
Thanks for the logs.
I'm seeing log flooding from attempts to hack into your NAS. Have you port forwarded SSH?I can see other packages on the system such as Transmission.
With all you've done it may be advisable to backup your data, do a factory default (wipes all data, settings, everything) and restore your data from backup.
Be sure to change your password before enabling SSH again and/or disable password authentication when enabling SSH again.- jiska78Aug 15, 2016Tutor
Yes I opened up SSH for Netgear Support.
Factory Defaulting a unit is not a fix - that's a "I have no idea what the problem is, just start again"
