shaunob1
Aug 01, 2015Aspirant
Qbittorent Update Problems
I used Possin's qbittorrentr6_3.3.0_armel.deb from the community dropbox and ever since then I can not access the web interface. The default password of admin and adminadmin are not working nor was m...
- Sep 12, 2015
Ok I found the solution on my own. The location for the "qBittorrent.conf" file was hard to find but I found it in the end. The location was /home/admin/.config/qBittorrent
I then followed the guide on here and now it works a treat.. https://github.com/qbittorrent/qBittorrent/wiki/I-forgot-my-UI-lock-passwordpwd
Problem solved
BrianL2
Aug 01, 2015NETGEAR Employee Retired
Hi shaunob1,
You may want to try OS reinstall. This procedure will reset the admin page password to the default and device ethernet settings. More importantly, it won't do anything to your existing data. Once you're able to login, download the Qbittorent Client here and ensure you will select the appropriate add-on for your ReadyNAS system.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
