shaunob1
Aug 01, 2015Aspirant
Qbittorent Update Problems
I used Possin's qbittorrentr6_3.3.0_armel.deb from the community dropbox and ever since then I can not access the web interface. The default password of admin and adminadmin are not working nor was m...
- Sep 12, 2015
Ok I found the solution on my own. The location for the "qBittorrent.conf" file was hard to find but I found it in the end. The location was /home/admin/.config/qBittorrent
I then followed the guide on here and now it works a treat.. https://github.com/qbittorrent/qBittorrent/wiki/I-forgot-my-UI-lock-passwordpwd
Problem solved
Aug 02, 2015Guru - Experienced User
shaunob1 wrote:
I used Possin's qbittorrentr6_3.3.0_armel.deb from the community dropbox and ever since then I can not access the web interface. The default password of admin and adminadmin are not working nor was my original password from the old version. I have tried removing and installing again. I have SSH access does anyone know how to disable the password ?
I am thinking you mean the qbittorent admin password, not the ReadyNAS password - correct?
https://github.com/qbittorrent/qBittorrent/wiki/I-forgot-my-UI-lock-password might help. Though I think qbittorrent.conf will be somewhere in /data/.apps
