shaunob1
Aug 01, 2015Aspirant
Qbittorent Update Problems
I used Possin's qbittorrentr6_3.3.0_armel.deb from the community dropbox and ever since then I can not access the web interface. The default password of admin and adminadmin are not working nor was m...
- Sep 12, 2015
Ok I found the solution on my own. The location for the "qBittorrent.conf" file was hard to find but I found it in the end. The location was /home/admin/.config/qBittorrent
I then followed the guide on here and now it works a treat.. https://github.com/qbittorrent/qBittorrent/wiki/I-forgot-my-UI-lock-passwordpwd
Problem solved
shaunob1
Aug 03, 2015Aspirant
Hi yes sorry I am talking about the Qbittorent interface. It shows up but no password will work on it. My ol;d password or the default one. My Readynas works fine and have had no trouble with the OS on it. Only Qbittorrent issues with the dropbox update. I have managed to go back to the preinstalled version however it is so dated now and I can't use it with Firefox as it has bugs which make it useless. I don't want to use Chrome due to privacy concerns.
I tried looking in the qbittorrent.conf using nano but it had nothing in there, completely empty I have also tried https://github.com/qbittorrent/qBittorrent/wiki/I-forgot-my-UI-lock-password and this did not help as there was nothing in the config file to edit.
