shaunob1
Aug 01, 2015Aspirant
Qbittorent Update Problems
I used Possin's qbittorrentr6_3.3.0_armel.deb from the community dropbox and ever since then I can not access the web interface. The default password of admin and adminadmin are not working nor was m...
- Sep 12, 2015
Ok I found the solution on my own. The location for the "qBittorrent.conf" file was hard to find but I found it in the end. The location was /home/admin/.config/qBittorrent
I then followed the guide on here and now it works a treat.. https://github.com/qbittorrent/qBittorrent/wiki/I-forgot-my-UI-lock-passwordpwd
Problem solved
shaunob1
Sep 12, 2015Aspirant
I have still not found any solution to this problem
shaunob1
Problem solved
