dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
chrispeachey
Mar 10, 2016Aspirant
Yeh. Thats the app store version. Hasnt worked for a few fw updates now. How to i load the new versions manually? I have a rn102 with newest fw update. When i open qbittorrent it opens and it all seems to be working. Apart from adding torrents. Nothing shows up anywhere after i add them
- BrianL2Mar 10, 2016NETGEAR Employee Retired
Hi chrispeachey,
Let's ask the developer super_poussin for some help.
Kind regards,
BrianL
NETGEAR Community Team- chrispeacheyMar 14, 2016Aspirant
no go then...
- ATCISMar 14, 2016Tutor
chrispeachey wrote:no go then...
Did you happen to try the step by step instructions provided five (6 including this one) posts ago? If so, and it did NOT work, please provide some additional details as to where things went wrong. . .
