dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
dsm1212
Mar 21, 2015Apprentice
I got off my butt and set up a build environment in a virtualbox and was able to build v3.1.12 fine. I installed super's addon and then dropped libtorrent-rasterbar.so.7 into /usr/lib and updated qbittorrent-nox. Those two files were all that was needed and it runs fine.
steve
steve
