dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
dsm1212
Apr 07, 2015Apprentice
The 1.0.3 deb package is still there. BTW What readynas box do you have? When super has "all" in the name of the deb package I think that means it supports all architectures. I had only given him the update for amd64 which would match all the more powerful boxes with "desktop" intel processors, I'm not sure about others. Or he found I was requiring a library that isn't there by default. Or there is a config upgrade issue. Hard to tell what problem is in play knowing only that it won't start :-).
steve
steve
