dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
dsm1212
May 13, 2015Apprentice
I'm not sure if it was because of h3nk3t's problems but Super pulled it. If you are SSH comfortable I can PM you the two files you need to replace to upgrade. I fear there was some lib dependency I previously satisfied on my nas that I don't know about. If the new version doesn't run for you we could probably see from ldd what is missing. Let me know if you want to try it.
steve
steve
