dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
chopin70
May 13, 2015Virtuoso
dsm1212 wrote: I'm not sure if it was because of h3nk3t's problems but Super pulled it. If you are SSH comfortable I can PM you the two files you need to replace to upgrade. I fear there was some lib dependency I previously satisfied on my nas that I don't know about. If the new version doesn't run for you we could probably see from ldd what is missing. Let me know if you want to try it.
steve
thanks
I am fine with SSH and linux commands. However, I mainly wanted to test latest version to see if it adds tracker edit. For now, I found that only uTorrent can remove trackers from the torrent. Other clients can at best add trackers, not edit existing ones. Only issue I have with uTorrent 3.0 is that after restart, it won't resume torrents. It also doesn't take into account the changes I do in the conf file. Only changes in GUI. It was a bit tough to configure properly the share permissions so that it accepts them. It needs admin rw rights on the share.
Does the latest Qbittorrent permits removing some trackers? If not, then no real need for me to try it
Thanks again
