dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
chopin70
May 14, 2015Virtuoso
Thanks for all your follow up
Here's utorrent version I use:
It is latest from Super Poussin dropbox.
When I turnoff the nas or restart it, the queue is emptied. Seeds and downloads are removed from the list.
One time only they showed stopped
I had no issues on OS 4.x and uTorrent v2.0
This started with OS 6 and uTorrent v3.0
I do not have "Automatically load torrents from" checked. I tried to check it but it won't change any thing
edit: Disabling write caching seems to fix the issue. The torrents status remains, however, in download torrents can end stopped on restart. But at least they do not disappear
