dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
dsm1212
May 14, 2015Apprentice
You mean write caching in utorrent right? I found that if I tried to tweak the utorrent settings too much I often got myself into trouble. Torrents not finishing correctly or whatever. Occasionally I'd have to wipe the settings and restart from the .conf file to get back to a sane state.
Using OS6 there is a newer utorrent 3.3. See the debian 7 64 bit version here: http://www.utorrent.com/downloads/linux
See the discussion link on that page for more info.
You would have to replace the executable yourself. ssh in, stop utorrent, move aside the one that is there so you don't lose it, drop this one in it's place, restart utorrent. I no longer have it installed, but I did that with every new version and it worked so it should.
steve
steve
