dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
chopin70
May 15, 2015Virtuoso
thank you
I verified, and it is same version as latest one from super poussin repo. Same "About" dialog as I posted above: 3.3
There are very tiny changes in header and tail of files between your link and super poussin. I don't know why those changes!
By the way, you can also change the files using windows explorer logged with a user with root access. I verified and the NAS automatically CHMOD the files to highest rights, even too high, but faster than SSH ;-)
Maybe it is just because of bugs, since it is alpha
I could end with reverting to 2.x which worked great in OS 4. v2.2 and higher needed low level hacking of some libc that I didn't want to do to avoid breaking other things
