dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
mdgm-ntgr
May 24, 2015NETGEAR Employee Retired
That is the dropbox he was referring to.
I can't see it in there other.
I have reached out to super-poussin.
The new version will only run on x86_64 systems however unfortunately it can only be built as an app that appears to be for all systems. It is not safe to install on ARM.
