dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
hfsamb
Jun 08, 2015Aspirant
I am currently using my brand new 102 for development and application porting which I intend to use latter. After I have all apps I need I will do a factory restore and just install the built applications.
Do you know how long until alpha is released or rejected? I could revert to 3.2.0 if it takes too long.
Does 'add torrents from file' and 'scan watched folder' work in 3.2.0 version?
