dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
hfsamb
Jul 01, 2015Aspirant
Easy solution is to uninstall and install it again.
If you want to keep your preferences then login with ssh and edit the config file.
/home/admin/.config/qBittorrent/qBittorrent.conf
Then look for IPFilter\BannedIPs=... and erase your tablet's IP.
Newer qb versions offer better browser compatility. Check the community dropbox.
