dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
shaunob1
Aug 01, 2015Aspirant
Hello I installed qbittorrentr6_3.3.0_armel.deb from the dropbox folder but I can no longer log into the web ui. I have tried the default password of admin and adminadmin also my previous credentials but I just can't get it to work. It seems to be running fine. I have SSH access is there any files I can edit to remove the password or change it?
the .config/qBittorrent/qBittorrent.conf file is empty.
I would be greatful for any help to get this working thanks
Results of ldd /usr/bin/qbittorrent-nox
libz.so.1 => /lib/arm-linux-gnueabi/libz.so.1 (0x40244000)
libtorrent-rasterbar.so.8 => /usr/lib/libtorrent-rasterbar.so.8 (0x40262000)
libboost_system.so.1.49.0 => /usr/lib/libboost_system.so.1.49.0 (0x4003a000)
libpthread.so.0 => /lib/arm-linux-gnueabi/libpthread.so.0 (0x400e3000)
libQtNetwork.so.4 => /usr/lib/arm-linux-gnueabi/libQtNetwork.so.4 (0x4054e000)
libQtCore.so.4 => /usr/lib/arm-linux-gnueabi/libQtCore.so.4 (0x40680000)
libstdc++.so.6 => /usr/lib/arm-linux-gnueabi/libstdc++.so.6 (0x40920000)
libm.so.6 => /lib/arm-linux-gnueabi/libm.so.6 (0x40183000)
libgcc_s.so.1 => /lib/arm-linux-gnueabi/libgcc_s.so.1 (0x4010c000)
libc.so.6 => /lib/arm-linux-gnueabi/libc.so.6 (0x409fb000)
/lib/ld-linux.so.3 (0x40065000)
libssl.so.1.0.0 => /usr/lib/arm-linux-gnueabi/libssl.so.1.0.0 (0x40b41000)
libcrypto.so.1.0.0 => /usr/lib/arm-linux-gnueabi/libcrypto.so.1.0.0 (0x40b93000)
librt.so.1 => /lib/arm-linux-gnueabi/librt.so.1 (0x400a8000)
libdl.so.2 => /lib/arm-linux-gnueabi/libdl.so.2 (0x400c7000)
libglib-2.0.so.0 => /lib/arm-linux-gnueabi/libglib-2.0.so.0 (0x40d00000)
libpcre.so.3 => /lib/arm-linux-gnueabi/libpcre.so.3 (0x40136000)
Edit: I managed to get 1.0.3 working again by running apt-get purge qbittorrent-nox in SSH but I still would like to use the latest one any help would be great thanks.
- ATCISOct 28, 2015Tutor
Can this update be installed from the GUI, or is it exclusively command line only? I tried it from the GUI and got this error message:
ReadyNAS-Pro-2
Cannot install application D:\Downloads\qbittorrentr6_3.3.0_amd64.deb Thanks in advance!
- StephenBOct 28, 2015Guru - Experienced User
ReadyNAS-Pro-2
.deb is for OS 6, not OS 4.2. there's a TransmissionBT add-on available from WhoChares for the Pro (with a small charge) at rnxtras.com
I don't recall seeing any references to a qbittorrent add-on packaged for 4.2.x firmware.
- ATCISOct 29, 2015Tutor
ATCIS wrote:Can this update be installed from the GUI, or is it exclusively command line only? I tried it from the GUI and got this error message:
ReadyNAS-Pro-2
In case anyone else runs in to this same issue, I was able to answer my own question (since no one else chimed in). Here is how I did it:
- Upload qbittorrentr6_3.3.0_amd64.deb to a directory on the NAS of your choosing (I used /root)
- (Credit to h3nk3t for this idea from and earlier post) apt-get purge qbittorrent-nox (removes remnants of version 1.03)
- apt-get install qbittorrent-nox (updates qbittorrent-nox to version 2.9.x)
- dpkg -i qbittorrentr6_3.3.0_amd64.deb apt-get install -f <--- I'm not a Linux Guru, so I'm not sure that last part was required
- Profit !!!
- chrispeacheyMar 10, 2016Aspirant
Hello, Iv been looking for a solution to this for a while, i have a background in IT but never gone into coding etc. can someone point me in the right direction to updating qbittorrent on my nas? i see these instructions here but dont know how to get to this stage. have very basic command promt skills so once rolling i should be ok.
