dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
shaunob1
Aug 01, 2015Aspirant
Hello I installed qbittorrentr6_3.3.0_armel.deb from the dropbox folder but I can no longer log into the web ui. I have tried the default password of admin and adminadmin also my previous credentials but I just can't get it to work. It seems to be running fine. I have SSH access is there any files I can edit to remove the password or change it?
the .config/qBittorrent/qBittorrent.conf file is empty.
I would be greatful for any help to get this working thanks
Results of ldd /usr/bin/qbittorrent-nox
libz.so.1 => /lib/arm-linux-gnueabi/libz.so.1 (0x40244000)
libtorrent-rasterbar.so.8 => /usr/lib/libtorrent-rasterbar.so.8 (0x40262000)
libboost_system.so.1.49.0 => /usr/lib/libboost_system.so.1.49.0 (0x4003a000)
libpthread.so.0 => /lib/arm-linux-gnueabi/libpthread.so.0 (0x400e3000)
libQtNetwork.so.4 => /usr/lib/arm-linux-gnueabi/libQtNetwork.so.4 (0x4054e000)
libQtCore.so.4 => /usr/lib/arm-linux-gnueabi/libQtCore.so.4 (0x40680000)
libstdc++.so.6 => /usr/lib/arm-linux-gnueabi/libstdc++.so.6 (0x40920000)
libm.so.6 => /lib/arm-linux-gnueabi/libm.so.6 (0x40183000)
libgcc_s.so.1 => /lib/arm-linux-gnueabi/libgcc_s.so.1 (0x4010c000)
libc.so.6 => /lib/arm-linux-gnueabi/libc.so.6 (0x409fb000)
/lib/ld-linux.so.3 (0x40065000)
libssl.so.1.0.0 => /usr/lib/arm-linux-gnueabi/libssl.so.1.0.0 (0x40b41000)
libcrypto.so.1.0.0 => /usr/lib/arm-linux-gnueabi/libcrypto.so.1.0.0 (0x40b93000)
librt.so.1 => /lib/arm-linux-gnueabi/librt.so.1 (0x400a8000)
libdl.so.2 => /lib/arm-linux-gnueabi/libdl.so.2 (0x400c7000)
libglib-2.0.so.0 => /lib/arm-linux-gnueabi/libglib-2.0.so.0 (0x40d00000)
libpcre.so.3 => /lib/arm-linux-gnueabi/libpcre.so.3 (0x40136000)
Edit: I managed to get 1.0.3 working again by running apt-get purge qbittorrent-nox in SSH but I still would like to use the latest one any help would be great thanks.
ATCIS
Oct 28, 2015Tutor
Can this update be installed from the GUI, or is it exclusively command line only? I tried it from the GUI and got this error message:
ReadyNAS-Pro-2
Thanks in advance!
- StephenBOct 28, 2015Guru - Experienced User
ReadyNAS-Pro-2
Cannot install application D:\Downloads\qbittorrentr6_3.3.0_amd64.deb Thanks in advance!
.deb is for OS 6, not OS 4.2. there's a TransmissionBT add-on available from WhoChares for the Pro (with a small charge) at rnxtras.com
I don't recall seeing any references to a qbittorrent add-on packaged for 4.2.x firmware.
- ATCISOct 29, 2015Tutor
ATCIS wrote:Can this update be installed from the GUI, or is it exclusively command line only? I tried it from the GUI and got this error message:
ReadyNAS-Pro-2
In case anyone else runs in to this same issue, I was able to answer my own question (since no one else chimed in). Here is how I did it:
- Upload qbittorrentr6_3.3.0_amd64.deb to a directory on the NAS of your choosing (I used /root)
- (Credit to h3nk3t for this idea from and earlier post) apt-get purge qbittorrent-nox (removes remnants of version 1.03)
- apt-get install qbittorrent-nox (updates qbittorrent-nox to version 2.9.x)
- dpkg -i qbittorrentr6_3.3.0_amd64.deb apt-get install -f <--- I'm not a Linux Guru, so I'm not sure that last part was required
- Profit !!!
- chrispeacheyMar 10, 2016Aspirant
Hello, Iv been looking for a solution to this for a while, i have a background in IT but never gone into coding etc. can someone point me in the right direction to updating qbittorrent on my nas? i see these instructions here but dont know how to get to this stage. have very basic command promt skills so once rolling i should be ok.
- BrianL2Mar 10, 2016NETGEAR Employee Retired
Hi chrispeachey,
The latest Qbittorrent add-on version for OS 6 is 1.0.3. Do you have the same version installed in your machine? Are you having problems too?
Kind regards,
BrianL
NETGEAR Community Team
