dsm1212
Mar 12, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
ATCIS
Oct 28, 2015Tutor
Can this update be installed from the GUI, or is it exclusively command line only? I tried it from the GUI and got this error message:
ReadyNAS-Pro-2
Thanks in advance!
Oct 28, 2015Guru - Experienced User
ReadyNAS-Pro-2
Cannot install application D:\Downloads\qbittorrentr6_3.3.0_amd64.deb
Thanks in advance!
.deb is for OS 6, not OS 4.2. there's a TransmissionBT add-on available from WhoChares for the Pro (with a small charge) at rnxtras.com
I don't recall seeing any references to a qbittorrent add-on packaged for 4.2.x firmware.
