NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
NAStools
Nov 30, 2016Luminary
Home Assistant v0.33.4-nt1 released! Check out more information in the first post of this thread.
- kevcomptonDec 14, 2016Apprentice
Hi,
I would like to be able to use the latest version of Home Assistant so I can use my Harmony Hub but the version you have created a ReadyNAS app for appears not to be able to update, I think this is a common problem with this version of Home Assistant based on me searching the web.
Error shows:
16-12-01 10:16:30 homeassistant.core: Error doing job: Future exception was never retrieved Traceback (most recent call last): File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run result = self.fn(*self.args, **self.kwargs) File "/apps/nastools-homeassistant/homeassistant/lib/python3.4/site-packages/homeassistant/components/updater.py", line 74, in <lambda> hass, lambda _: check_newest_version(hass, huuid), File "/apps/nastools-homeassistant/homeassistant/lib/python3.4/site-packages/homeassistant/components/updater.py", line 82, in check_newest_version newest, releasenotes = get_newest_version(huuid) File "/apps/nastools-homeassistant/homeassistant/lib/python3.4/site-packages/homeassistant/components/updater.py", line 128, in get_newest_version return (res['version'], res['release-notes']) TypeError: 'NoneType' object is not subscriptable
Are you able to show me how to upgade to the latest version or are you able to update you app?
Many thanks.
- NAStoolsDec 14, 2016Luminary
kevcompton wrote:I would like to be able to use the latest version of Home Assistant so I can use my Harmony Hub[...]
I've updated to v0.34.5.
NASTools,
Thank you for updating Home Assistant, much appreciated.
It's great that we've got someone finally who is knocking out current apps that are so very useful.
I've spent a lot of money in the past on numerous ReadyNAS products and still can't understand why Netgear can't employ someone like yourself who can create so many useful apps. A NAS is not just for storing data, it can and should be so so much more.
Please keep up the excellent work.
Kevin
