NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
kevcompton
Dec 14, 2016Apprentice
Hi,
I would like to be able to use the latest version of Home Assistant so I can use my Harmony Hub but the version you have created a ReadyNAS app for appears not to be able to update, I think this is a common problem with this version of Home Assistant based on me searching the web.
Error shows:
16-12-01 10:16:30 homeassistant.core: Error doing job: Future exception was never retrieved Traceback (most recent call last): File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run result = self.fn(*self.args, **self.kwargs) File "/apps/nastools-homeassistant/homeassistant/lib/python3.4/site-packages/homeassistant/components/updater.py", line 74, in <lambda> hass, lambda _: check_newest_version(hass, huuid), File "/apps/nastools-homeassistant/homeassistant/lib/python3.4/site-packages/homeassistant/components/updater.py", line 82, in check_newest_version newest, releasenotes = get_newest_version(huuid) File "/apps/nastools-homeassistant/homeassistant/lib/python3.4/site-packages/homeassistant/components/updater.py", line 128, in get_newest_version return (res['version'], res['release-notes']) TypeError: 'NoneType' object is not subscriptable
Are you able to show me how to upgade to the latest version or are you able to update you app?
Many thanks.
NAStools
Dec 14, 2016Luminary
kevcompton wrote:I would like to be able to use the latest version of Home Assistant so I can use my Harmony Hub[...]
I've updated to v0.34.5.
