funglenn
Jan 29, 2017Luminary
Help and questions on Virtualbox install for 6.6.0
Looking to install Virtualbox 6.6.0 and this is going to seem like a dumb questions, sorry, new and learning. Once it is installed, how do you it up? is it all done via command line? is there a gui...
- Feb 12, 2017
Thank you all! it works. This is the commands I used, with
VBoxHeadless --startvm <uuid|name> --vrde on
to run the script.
unzip ReadyNASOS_V6.6.0_WW_src.zip
cp -rp linux-4.1.30-x86_64 /data/.apps
ln -s /data/.apps/linux-4.1.30-x86_64 /usr/src/linux-4.1.30-x86_64apt-get update
apt-get install build-essential
apt-get install vim git lm-sensors telnet
apt-get install bc
apt-get install libqt4-opengl libvpx1
apt-get install -f
export KERN_DIR=/usr/src/linux-4.30-x86_64
cd /usr/src/linux-4.1.30-x86_64
cp /data/VirtualBox/tmp/linux-4.1.30-x86_64/arch/x86/configs/defconfig.x86 /usr/src/linux-4.1.30-x86_64/.config
# ** Check kernel install options and modules
make ARCH=x86_64 oldconfig && make ARCH=x86_64
## Installation of VirtualBox
cd /data/VirtualBox/
dpkg -i virtualbox-4.3_4.3.20-96996~Debian~wheezy_amd64.deb
apt-get -f install
/etc/init.d/vboxdrv setup
modprobe vboxdrvcd
## Upgrade VirtualBox Extension Pack
VBoxManage extpack uninstall "Oracle VM VirtualBox Extension Pack"
VBoxManage extpack install Oracle_VM_VirtualBox_Extension_Pack-4.3.20-96996.vbox-extpack
jpearn
Feb 07, 2017Star
Have you tried :
apt-get install bc
I think it was also missing from the other instructions.
funglenn
Feb 12, 2017Luminary
to run the script.
apt-get update
apt-get install bc
apt-get install -f
apt-get -f install
modprobe vboxdrv
cd
